Browse Forums Bathrooms and Laundry 1 Mar 12, 2008 11:41 am My recently purchased unit has a bathroom and a toilet room. The toilet room has these really tiny tiles, like 3cm each. I want to change them and my renovator said the cheaper way would be to put new tiles over them, lifting the floor up by 7mm.
I don't know how this would look as I'll have floorboards installed. Does anyone have any experience with slightly elevated tiles and whether it will be a pain to look at or use? Re: Floor tiles over existing ones 2Mar 12, 2008 1:22 pm You want cheap or something you can live with?
Another 7mm may not sound like much but it would be enough to catch your toe, plus the hassle of something extra 7mm high to cover the edge of the tiles. If it were me, I'd rip em up and do it properly. Re: Floor tiles over existing ones 3Mar 12, 2008 11:52 pm ditto
Our old house had so many layers on the floors that it was an archeological dig back in history to find the base floor. Do the job right and it will look better; particularly if you plan on living there. You will always have the satisfaction of knowing that you did it properly. Whenever we renovated we tried to do it in a way that was sympathetic with the original integrity of the house. Re: Floor tiles over existing ones 4Mar 15, 2008 12:53 pm ![]() You want cheap or something you can live with? Another 7mm may not sound like much but it would be enough to catch your toe, plus the hassle of something extra 7mm high to cover the edge of the tiles. If it were me, I'd rip em up and do it properly. I agree!!! ![]() Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Floor tiles over existing ones 5Mar 15, 2008 10:08 pm Never seen it live, but have a look at the vinylover the top option.
There is supposed to be some stuff that does the job very well. and only a 2mm increase and far less costs. But as will all options. - you have to weigh up the hosue, what else needs doing etc etc. Steve Re: Floor tiles over existing ones 6Mar 28, 2008 4:54 pm Taking up old ceramic tile is pretty easy if you have the right tools. You should be able to hire something to do it yourself at Kinnards.
If it's a really small area, you just need a small chisel and a hand floor scraper. If a larger area and on concrete, they have a large scraper/chisel/prybar you can use. Greg Re: Floor tiles over existing ones 7Mar 28, 2008 8:07 pm Quote: Taking up old ceramic tile is pretty easy if you have the right tools. You should be able to hire something to do it yourself at Kinnards. Ash will love you Gpierce. They sell rope ![]() Kennards do the hire stuff, but we know what you meant. And yep a hired chisel nosed tile scraper works a treat. Steve Re: Floor tiles over existing ones 8Mar 28, 2008 9:41 pm Kinnards, Kennards, tomato, potato:)
Thanks:) Greg Re: Floor tiles over existing ones 9Apr 14, 2008 9:17 pm Best thing for ripping up those tiles...
Spend a hard earned $49 at Bunnings on an Ozito 1050W hammer drill which comes with a chisel point. I know what most people are thinking, but it will be the best $49 that you ever spend. I'm a big beliver in quality tools when required. This thing just goes, and goes, and goes, and goes... Great for mixing tile adhesive also, as it's got so much torque you can mix a full 20 litre bucket with no issues. So while your at Bunnings, spend another $14 on an Auger mixing piece. If you do decide to tile over the top, there are plenty of glues on the market that are made for that purpose. Just make sure the base tiles are clean, and usually you have a prep of some sort. You can get some nice stainless trims which are graduated so that the edge isn't sharp. Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Floor tiles over existing ones 10May 01, 2008 1:57 pm Well if it's only 7mm u must be use a 2mm thick tile. By the time u lay say a 10mm (min) layer of adhesive using your notched trowel, you will still end up with say at least 5mm (min) once you compress it under the tile. Now depending on the thickness of the tile - lets say ur using a 200x200 at min 7-8mm...well theres 12-13mm already.
The other point is even if you do replace them you still may end up with a slighter higher floor - as im sure you new tile want be as thin as the old mosaic. Its easier to control in a bathroom where u have a sand and cement bed above the concrete floor. When re screeding the floor prior to laying tiles - you can compensate for the increased tile thickness.. Ciao Looks like water damage. Best practice would be to take down the whole area wall covering and floor. May be worse and spread more than you think. Pull up vinyl (looks… 1 5866 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 1519 ![]() So my laundry is very outdated. The floor is this hideous green colour. have seen people overseas painting over this but worried about the longevity and the proper… 0 6224 |
