Browse Forums Bathrooms and Laundry Re: Enduroshield - DIY or get the pros to install 21Feb 04, 2013 2:14 pm TwoFatKitties - I agree 110%...All it takes is a quick squeegee after each other (10 seconds max) how hard can it be!!...We bought ours from Ikea for $1 and it works brilliantly... We trained our kids to do the same and it worked a treat as otherwise it was their responsibility to clean their bathroom hahaha I agree Tengals, Mr Sheen is a nightmare and does nothing but create more headaches lol...Soooo Jodge DONT DO IT!!!! I have heard that shaving foam works well but i think that might be for steam on mirrors and not soap scum.... Enduroshield or similar is definitely the way to go... Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Re: Enduroshield - DIY or get the pros to install 23Feb 08, 2015 6:01 pm I find just after each shower wetting down shower screen . And there is also a windex shower spray .soray and leave it on to dry. I dont like any cleaner to just leave on to dry .so I mixed mine with water and wiped it on . I also find that normal windex diluted with water works good ( cleaner gave me that tip ) also if you clean them on a weekly basis then you wont have a build up . Re: Enduroshield - DIY or get the pros to install 24Feb 09, 2015 8:32 pm I,m a ocd cleaner of showers, and best ever advice was to stop using soap and only use liquid soap, makes a huge difference when the liquid soap won't harden up, soap bar residuel hardens up on surfaces creating soap scum. I just use window sqee gee after showers, and moved into new house November 2014, and shower still spotless today without any chemicals ever used,in summary,use liquid soap, then window sqee gee. Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 10150 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 7527 |
