Browse Forums Bathrooms and Laundry 1 Apr 17, 2012 1:13 pm I have been asked to improve the shower in a rental property. At the moment it has a curtained corner shower. Of course the base slopes to a central floorwaste but, amazingly, there is no plinth (if that is the correct term) to prevent water from escaping onto the adjacent bathroom floor. I am thinking of building a two course plinth of 230x114x65 clay pavers and tiling it but I worry that normal mortar would not form a strong bond between the pavers and shiny floor tiles. Is my concern justified? Also, as it is a wet area should I add some Bondcrete to the mortar mix? Re: Building a Brick Plinth on a Bathroom Floor 2Apr 17, 2012 4:01 pm Alot of new bathrooms have walk in showers. No doors and no steps! 2 of the 3 bathrooms in my new house are being built this way. Aslong as the falls are correct they function perfectly! Very little will stick for long to a shinny tile. I personally would be drilling some holes in the tile (dont drill through the water proofing) this will allow the mortar to stick well. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8414 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11252 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 2172 |
