Browse Forums Bathrooms and Laundry 1 Mar 05, 2012 7:57 am When I am having a shower (in new bathroom), or when the vanity tap is running, I cannot hear water running down the drain. However once the shower (or tap) is turned off, with only a little water left to drain, I can hear it (from the grate on the floor). Given it is a new bathroom, with new pipes, and the water flows freely through the drain, I would assume the noise is not due to a blockage. What other reason could there be? Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8489 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18821 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4547 |
