Browse Forums Bathrooms and Laundry 1 Feb 29, 2012 8:07 pm I really like the Caroma liano under bench basin but I'm a little concerned that in order to have that basin, I might need to get a custom made vanity unit (1500mm long, likely to be double sink). How hideously expensive is it to get a custom-made vanity? Should I be thinking $1500+, $2000+ and kiss my dream good-bye? Otherwise, how does one find a vanity cabinet where you simply provide the sink and benchtop? Thanks in advance Peta Re: custom made vanity cabinets 2Mar 01, 2012 6:57 am Will the vanity be wall hung or have a kickboard? How many drawers? Custom made does cost a fair bit more than off the shelf BUT if its wall hung and a simple design you should be able to get it for around $1000-$1300 Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: custom made vanity cabinets 3Mar 03, 2012 10:04 pm One quote, for a 30 mm CS top, 2 sinks with a cupboards and 2 drawers each side, separated by a narrow open shelf, 2.4m wide, 550mm deep, at 900mm high resting on a supplied 200 mm plint in the back (so it looks wall hung), in polyurethane, we supply sinks and taps: $5000. For another bathroom, single sink, which is semi-recessed (so the CS is about 300 deep) and 1.2m wide, similar setup to above in that we supply sink and tap: $4000. In this case, we have decided to buy a Duravit Starck 1 sink and vanity (in walnut), as it was cheaper. Re: custom made vanity cabinets 4Mar 04, 2012 5:56 am PHL One quote, for a 30 mm CS top, 2 sinks with a cupboards and 2 drawers each side, separated by a narrow open shelf, 2.4m wide, 550mm deep, at 900mm high resting on a supplied 200 mm plint in the back (so it looks wall hung), in polyurethane, we supply sinks and taps: $5000. For another bathroom, single sink, which is semi-recessed (so the CS is about 300 deep) and 1.2m wide, similar setup to above in that we supply sink and tap: $4000. In this case, we have decided to buy a Duravit Starck 1 sink and vanity (in walnut), as it was cheaper. OMG! Those prices and you supply sinks and taps?! I'll start seriously hunting around for a pre-made vanity. As much as I like those basins, I don't like them that much, LOL! 2010, June : Land bought (1700sqm, battleaxe block). That's it so far! We're in the design phase .... Re: custom made vanity cabinets 5Mar 04, 2012 7:01 am Hence we decided to look around. Am expecting another quote back from another company, whose designer we actually liked after meeting with him, as he pointed out drawbacks, new ideas to improve what we wanted to do, and suggestions on bringing the price down without reducing quality. Re: custom made vanity cabinets 6Mar 11, 2012 5:17 pm Pete_n_Pet PHL One quote, for a 30 mm CS top, 2 sinks with a cupboards and 2 drawers each side, separated by a narrow open shelf, 2.4m wide, 550mm deep, at 900mm high resting on a supplied 200 mm plint in the back (so it looks wall hung), in polyurethane, we supply sinks and taps: $5000. For another bathroom, single sink, which is semi-recessed (so the CS is about 300 deep) and 1.2m wide, similar setup to above in that we supply sink and tap: $4000. In this case, we have decided to buy a Duravit Starck 1 sink and vanity (in walnut), as it was cheaper. OMG! Those prices and you supply sinks and taps?! I'll start seriously hunting around for a pre-made vanity. As much as I like those basins, I don't like them that much, LOL! Those prices are way way to high!!!!! The 2.4m Vanity should cost around $1500 - $2000 and the top depending on colour should cost around $1000 Dont be put off by someone that has been charged alot. Put a basic drawing together and email it to a few cabinet makers. Even email it to me and I can can let you know what its worth. I am building a 1.4m vanity for a customer at the minute. Full polyurethane with sharknose handles for $900. The customer is suppling the top and handles! The is a website that advertises CasearStone off cuts. These off cuts can be as big as 3000mm long!!! http://www.offcuts.com.au Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: custom made vanity cabinets 7Mar 11, 2012 9:11 pm CuttingEdgeKitchens Pete_n_Pet PHL One quote, for a 30 mm CS top, 2 sinks with a cupboards and 2 drawers each side, separated by a narrow open shelf, 2.4m wide, 550mm deep, at 900mm high resting on a supplied 200 mm plint in the back (so it looks wall hung), in polyurethane, we supply sinks and taps: $5000. For another bathroom, single sink, which is semi-recessed (so the CS is about 300 deep) and 1.2m wide, similar setup to above in that we supply sink and tap: $4000. In this case, we have decided to buy a Duravit Starck 1 sink and vanity (in walnut), as it was cheaper. OMG! Those prices and you supply sinks and taps?! I'll start seriously hunting around for a pre-made vanity. As much as I like those basins, I don't like them that much, LOL! Those prices are way way to high!!!!! The 2.4m Vanity should cost around $1500 - $2000 and the top depending on colour should cost around $1000 Dont be put off by someone that has been charged alot. Put a basic drawing together and email it to a few cabinet makers. Even email it to me and I can can let you know what its worth. We sent out for tenders, and two came out about the same. We ended up going with a cabinetmaker recommended by the builder as the price difference ended up being $10K. There is some additional cost from Tip-On I expect, as well as gloss finish. Re: custom made vanity cabinets 8Mar 11, 2012 9:55 pm CuttingEdgeKitchens Those prices are way way to high!!!!! The 2.4m Vanity should cost around $1500 - $2000 and the top depending on colour should cost around $1000 Dont be put off by someone that has been charged alot. Put a basic drawing together and email it to a few cabinet makers. Even email it to me and I can can let you know what its worth. I am building a 1.4m vanity for a customer at the minute. Full polyurethane with sharknose handles for $900. The customer is suppling the top and handles! The is a website that advertises CasearStone off cuts. These off cuts can be as big as 3000mm long!!! http://www.offcuts.com.au Thanks for that link. I've bookmarked it and signed up - it's fabulous! Here's a rough draft of what we want. At this stage, I haven't thought too much about the style of the drawer but possibly the fronts might be the type with sharknosed handles. Alternatively, straight edge laminated doors (2mm edge). 30mm stone bench with the Liano basin. What do you think? Too much? If the centre drawers are too much, would swap that to a cupboard with 1 internal shelf. 2010, June : Land bought (1700sqm, battleaxe block). That's it so far! We're in the design phase .... Re: custom made vanity cabinets 9Mar 11, 2012 9:58 pm PHL We sent out for tenders, and two came out about the same. We ended up going with a cabinetmaker recommended by the builder as the price difference ended up being $10K. There is some additional cost from Tip-On I expect, as well as gloss finish. Sorry, but what's Tip-On? 2010, June : Land bought (1700sqm, battleaxe block). That's it so far! We're in the design phase .... Re: custom made vanity cabinets 10Mar 12, 2012 1:31 pm Pete_n_Pet CuttingEdgeKitchens Those prices are way way to high!!!!! The 2.4m Vanity should cost around $1500 - $2000 and the top depending on colour should cost around $1000 Dont be put off by someone that has been charged alot. Put a basic drawing together and email it to a few cabinet makers. Even email it to me and I can can let you know what its worth. I am building a 1.4m vanity for a customer at the minute. Full polyurethane with sharknose handles for $900. The customer is suppling the top and handles! The is a website that advertises CasearStone off cuts. These off cuts can be as big as 3000mm long!!! http://www.offcuts.com.au Thanks for that link. I've bookmarked it and signed up - it's fabulous! Here's a rough draft of what we want. At this stage, I haven't thought too much about the style of the drawer but possibly the fronts might be the type with sharknosed handles. Alternatively, straight edge laminated doors (2mm edge). 30mm stone bench with the Liano basin. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What do you think? Too much? If the centre drawers are too much, would swap that to a cupboard with 1 internal shelf. I personally would just have one door in the middle. There is alot of extra work to make 2 x drawers and then have cutouts in them for plumbing. The prices I have done are based on a centre door. Supply only in Polyurethane with sharknose handles $1390 + GST Supplu only in laminex lamiwood with a 2mm PVC edge $990 + GST The polyurethane price is based on a standard white gloss. No bench tops included in the price. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: custom made vanity cabinets 11Mar 12, 2012 1:48 pm CuttingEdgeKitchens I personally would just have one door in the middle. There is alot of extra work to make 2 x drawers and then have cutouts in them for plumbing. The prices I have done are based on a centre door. Supply only in Polyurethane with sharknose handles $1390 + GST Supplu only in laminex lamiwood with a 2mm PVC edge $990 + GST The polyurethane price is based on a standard white gloss. No bench tops included in the price. Thank you so much for that. I had a feeling you'd say it would be easier to simply go with a cupboard in the centre. I reckon that's affordable, especially if we can source stone from the offcuts website. I saw a 1500mm vanity at Reece over the weekend and it was $1900 anyway. I am using that as my base price to convince DH to go with a custom made vanity .... ETA : when you say polyurethene, does that mean painted, like a 2-pac paint job? Or does that mean plastic-thermal wrapped? 2010, June : Land bought (1700sqm, battleaxe block). That's it so far! We're in the design phase .... Re: custom made vanity cabinets 12Mar 12, 2012 2:20 pm Pete_n_Pet [ETA : when you say polyurethene, does that mean painted, like a 2-pac paint job? Or does that mean plastic-thermal wrapped? Polyurethane = 2pac they are the same thing. For some reason the public call it 2pac Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16009 Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6737 |
