Browse Forums Bathrooms and Laundry 1 Feb 22, 2012 1:52 pm We are about to have tilers & plumbers strat on our full bathroom renovation. It involves relocating the position of the bath & vanity (essentially switching them around). The plumber has advised he needs the WHOLE floor & slab removed, but the tiles thinks it may not need to be completely removed, and that it can be patched up after the plumber does his thing. Can anyone advise if this is the normal procedure, or should it not need to come up completely? Re: Bathroom slab - do I need to remove it?? 2Feb 22, 2012 4:41 pm It could be done either way but really depends on your plumbing and where its coming from in the room. Very hard to give you an exact answer without all the info. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 0 1347 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5944 |
