Browse Forums Bathrooms and Laundry 1 Jan 20, 2012 9:36 pm There's a property I am looking at purchasing and here are some pictures I took in the ensuite. Door Frame http://i39.tinypic.com/29apkkk.jpg http://i39.tinypic.com/qzjk2e.jpg Tiling and Soap Holder http://i44.tinypic.com/1zoxly1.jpg One tile above the previous pic http://i44.tinypic.com/oqae5y.jpg Tile http://i44.tinypic.com/mc5028.jpg shower head http://i43.tinypic.com/21lsuvr.jpg Other side of the wall is the master bedroom (http://i39.tinypic.com/35lcgox.jpg). When I knock on a few of the tiles on that wall, it sounds hallow. The ensuite only has a skylight. No window in it. A second building inspection is on its way to see just how big an extent the issue is. From the original building inspection: Skirting and Architrave Ensuite door jamb and architrave, operational defect, swelling evident from the water damage and roughly patched. (This is recommended to replace for cosmetics) Tiles Ensuite shower walls, operational defect, areas of grout deterioration and some drummy and cracked tiles. (This is recommended to regrout) Bathroom shower wall some drummy tiles. Damp Issue Bedroom 1 (Master bedroom) wall adjoining shower, operationg defect, high moisture levels evident indicating some water leakage is occuring. (recommended reseal shower) Just wondering if this is a shower water leakage issue and would require reparing the shower? How much would this type of work cost roughly? This is 100% true. You can not hang anything on steel frames. very frustrating 8 8044 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3549 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6144 |
