Browse Forums Bathrooms and Laundry 1 Jan 08, 2012 8:51 am I am about to get a quote or two for the supply and installation of a shower screen (The current screen is looking old and the glass just looks foggy, even after cleaning, so it has to be removed) It is 87 cm by 89 cm and sits against two corner walls I am thinking semi frame-less with perhaps a swinging door and a one third fixed panel on the front to replace the current 3 part sliding door Can anyone help me with a ball figure approximate cost for the work, please, as I have no real idea of the going rates? Also any thoughts on clear glass versus frosted? Thank you Re: Approximate cost of shower screen 2May 28, 2012 8:54 pm try bunnings, got a great frameless for only a couple of hundred dollars, gotta install but probably not too hard to do cheers Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11161 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7063 2 4475 |
