Browse Forums Bathrooms and Laundry Re: Wall mounted water filter tap 2Dec 05, 2011 1:08 pm Are you looking for a combination tap or one just for filtered water? You can use any tap you like as the system could be adapted to any setup so long as your plumbing rough in is done correctly. If you want an all in one chilled tap like a Zip system then you might be out of luck, but you can put a filter system on any tap. Re: Wall mounted water filter tap 3Dec 06, 2011 7:54 pm It will be a separate supply going through a double filter; because the flow rate is rather low, I don't think it would be suitable through a normal tap setup. I'd also prefer not to be paying for another of these taps because we only need cold supply. Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72413 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1706 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7507 |
