Browse Forums Bathrooms and Laundry Re: urrrgh help Di Lorenzo Quote was 19.5K above standard su 21Dec 13, 2011 11:53 am Yes we did the same swapped the alfresco and back room over as that way our alfresco is on the better side.... How did you go with Kitchen and electrical upgrades did you have to spend alot on each? I would have loved a fireplace but thats on my wish list. Did you require bushfire bal? we require 12.5 bal but they cant yet give us an exact cost which scares me a little. Re: urrrgh help Di Lorenzo Quote was 19.5K above standard su 22May 28, 2012 12:39 am Just came across this thread- with Wisdom homes, if you do your own floors, does it have to be after handover or have people been able to get their own tradies in to do the floors prior to handover? I know they can tack on the skirting boards so you can do it afterwards, but it'd be nice to know if we can do it pre-handover Re: urrrgh help Di Lorenzo Quote was 19.5K above standard su 23May 28, 2012 6:54 am trayracer Just came across this thread- with Wisdom homes, if you do your own floors, does it have to be after handover or have people been able to get their own tradies in to do the floors prior to handover? I know they can tack on the skirting boards so you can do it afterwards, but it'd be nice to know if we can do it pre-handover Hi, trayracer, I think it's after handover... They won't let other tradies disturbing or might postponed their job... urrrgh help Di Lorenzo Quote was 19.5K above standard supply 24Oct 02, 2012 9:09 pm Is there a choice of floating/wood floors in the standard dilorenzo range? Our builder uses them That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8646 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20616 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11763 |
