Browse Forums Bathrooms and Laundry urrrgh help Di Lorenzo Quote was 19.5K above standard supply 24Oct 02, 2012 9:09 pm Is there a choice of floating/wood floors in the standard dilorenzo range? Our builder uses them That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8646 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20617 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11763 |
