Browse Forums Bathrooms and Laundry 1 Sep 21, 2011 10:39 am We just finished completely redoing our bathroom. We did a wet area shower (no hob) because my parents will be staying and disabled access is very important.
Overall working well, except the water from the shower floor is spreading *much* more across the floor than we'd like - sloping tiles aren't containing it as much as hoped, as a result after a shower the access to the toilet and vanity is quite wet. Did a bit of research and a collapsible neoprene or silicone barrier seems to be the answer, they're quite common in the states and Europe, e.g: http://www.allinonemobility-shop.com/coware.html Have not been able to find anything like this in Australia though, quite disappointing. Could anyone suggest materials or source for such? This is our shower: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks - Lindsay Re: Water dam/retainer for hobless wet area shower? 3Sep 21, 2011 11:39 am eyspy Cant help you with the hob, but what is your wall lining ? Curious as to what it is, how much, and what is it like to live with ? The wall lining is Zenolite Plus - its a high gloss laminate, very glass like in look and feel. We like it a *lot*. Easy to install, very easy to clean - just wipe with a microfibre cloth, no grout lines. Also used it for the splash back in our kitchen. Not cheap, though way cheaper than glass - Its approx $450 per 1000x2400 sheet. The aluminion extrusions for corners, joins and endcaps are about $30 per 3m length. Regards my water dam, I found Tyrex who make recycled rubber water retension barriers for showers - pretty much perfect for my needs. Also a business in Brisbane who do custom weighted shower curtains. Re: Water dam/retainer for hobless wet area shower? 4Sep 21, 2011 12:03 pm Shower panels look good,would you know what sizes it comes in.In pic looks like you have 1 and 1/2 panels on 1 side. Re: Water dam/retainer for hobless wet area shower? 5Sep 21, 2011 12:38 pm pattycake4 Shower panels look good,would you know what sizes it comes in.In pic looks like you have 1 and 1/2 panels on 1 side. Thanks As far as I know, it only comes in one size - 1000x2400mm, that's fine for a std floor to ceiling run. Yes, we do have 1.5 panels on one side - space constraints Its easy to cut with a good quality circular saw. Note:This is Zenolite *Plus* - specially hardened for bathrooms. There's also plain ordinary Zenolite (no plus) that comes in a larger variety of sizes, suitable for kitchen splashbacks etc. I go mine direct from HVG. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16559 If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12114 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3664 |
