Browse Forums Bathrooms and Laundry 1 Aug 31, 2011 1:13 pm Hi, I've just purchased a house built in 1977. I have discovered a leak in the shower in the ensuite. The brick wall behind the shower is showing signs of flaking and damage to the paint. In the actual shower some of the grout between the wall tiles is missing and I can see water dripping into the hole in the grout while it is running. Does anyone have any comments on using companies like Diamond Seal to fix a leaky shower? They offer a 12 year warranty. I am in Adelaide. Can anyone offer any suggestions for any other companies that do a good job at fixing this sort of thing? Re: Leak in shower 3Sep 26, 2012 8:41 am ^^ What he said. Anything else is just a short term bandaid solution and not worth the money in the long term. Quote: Does anyone have any comments on using companies like Diamond Seal to fix a leaky shower? They offer a 12 year warranty There are other companies around who do the same sort of thing as well but their warranties are next to useless. It is very hard or next to impossible to prove that their product has failed and their fine print will have something like " unforseen structural problems of the existing bathroom " or some other rubbish to absolve them of any wrongdoing. Usually we've found in the past that you end up doing the whole bathroom. You strip the whole room out and do the waterproofing to the whole floor and shower recess walls as well. Stewie If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20366 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5126 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17502 |
