Browse Forums Bathrooms and Laundry Re: Shower Recess - is it possible in apartment?? 3Nov 22, 2012 7:51 am xxkatxx yeah it is...you just add another brick wall! I'm getting one in my ensuite which is against an external double brick/cavity wall Add another brick wall? would this not jutt out? Can you please clarify cos I am challenged when it comes to understanding building. Re: Shower Recess - is it possible in apartment?? 4Nov 22, 2012 10:05 am well if you are building from new you just add another layer of wall and put the niche in that so 3 layers. if you are wanting to renovate then u would lose space doing this. not quite sure what you are up to considering you mentioned an apartment? Re: Shower Recess - is it possible in apartment?? 5Dec 02, 2012 1:18 pm xxkatxx well if you are building from new you just add another layer of wall and put the niche in that so 3 layers. if you are wanting to renovate then u would lose space doing this. not quite sure what you are up to considering you mentioned an apartment? We are renovating the apartment. The builder says that the bricks are old and he is concerned about damage and so he didnt put the shower recess in. You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36995 0 10282 |
