Browse Forums Bathrooms and Laundry Re: Shower tap or flick mixer? 3Aug 01, 2011 8:27 pm I'm not entirely sure...in the plans it just says tempered water to bathrooms, i'm assuming it just means the hot water is pre-mixed using a "tempering valve" with cold water to a temperature that can't burn you...my logic being that if the maximum temperature going into the mixer is lower, then it might be easier to get the temperature right... I'm hoping with the mixers its just a case of you get what you pay for...just been warned against them in showers by some...but i think they must of just been crappy mixers... that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7641 7 5276 Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6846 |
