Browse Forums Bathrooms and Laundry 1 Jul 17, 2011 7:46 pm Hi all , I need some advice I have discovered the shower has leaked into the floor boards and caused extensive damage which as we all know costs a bomb so I will be renovating . I have removed all old tiles, bath ,shower recess , vanity , villaboard and ripped up old floor , disconnected all plumbing and plugged all water sources . I have replaced old floor with yellow tongue as (previously installed) and I have checked joists and re-enforced accordingly. I was going to lay ply or ??? over shower floor (what options are there) and what is the most used ? as I have a pole home and concrete sheeting is very heavy and hard to get into position--- ? can i use ply on balance of floor ? to keep all the same height then apply membrane then tile ????? many thanks to all suggestions Re: full bathroom reno - help needed 2Jul 18, 2011 5:06 pm Hi, use only cement based tile underlay sheets 6mm ,glued and nailed as per marks on the sheet then waterproof as per Aust. standards. We renovate bathrooms and this is the acceptable method in your instance. Steve Re: full bathroom reno - help needed 3Jul 20, 2011 8:29 am Hi Bob thanks for the information ,I had researched this on the J Hardie website so it will work well and I will be waterproofed to Aust standards . I just wanted to ask what is the most common floor material used in shower floors these days and is ply the best option ? many thanks Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10434 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 10962 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8818 |
