Browse Forums Bathrooms and Laundry Re: LARGE glass panel for walk in shower 22Jul 04, 2011 7:03 pm alt0160 Oh hi! Haha, we want to do something very similar. Our quote was around 2k also. We are chasing 1910mm wide by 2000mm high (there was two hundred dollars difference between 10mm and 12mm glass). The biggest issue is getting it into the house. I was thinking about going to the ceiling, then I remembered the height of our door frames. Ive sent about 8 enquiries, had 3 responses. 2 said that it could be done, and one said seriously doubted that anyone who said they would do it has adequate knowledge of saftey. Our builder will do a semi framed one that is 1500 mm wide, by 2000mm high which is too small for what we are trying to do. They did suggest putting in a 410mm wall to make up the difference :/What state are you in? Maybe we can share our findings? We are building with V too. As above is what i'm thinking of doing in our ensuite,sml part wall & then a glass panel because our shower is a double but with 1 shower head. Did they quote you a price for this Be interesting what it is through them,but i wont a glass panel not semi frameless. cheers Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: LARGE glass panel for walk in shower 23Jul 04, 2011 7:05 pm pattycake4 I would still be happy to pay$285,much cheaper than shower companies Hiya Pced I think i will take a trip to bunnings & check them out Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: LARGE glass panel for walk in shower 24Jul 04, 2011 11:35 pm Mclaren .....Sorry off the subject but has anyone heard of doing something like this but smaller to install in a niche? We have two niches and I think slumped glass would look awesome if we were able to hang it in there. Any views?? Depending on the actual size of your niches (I gather you're talking about ones 1000mm-ish tall, not 400mm tall as in a shower niche) it could look pretty good. The only thing I'd caution is that sometimes (generally ??) slumped glass is a "bold" product, that is maybe why it works so well in large sheets. For your niches I'd probably be looking at a more "delicate" (less deep / pronounced) design for the glass ?? Or maybe tinted mirror ?? For fixing, say your niche "depth" was 90mm, I'd sit the glass / mirror flat into the niche, and then retain it with a 45mm * 45mm "beading" of some sort, painted seamlessly with the walls, so the glass would just appear to sit there with no fixing. In my mind anyhow !!! Cheers, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: LARGE glass panel for walk in shower 25Jul 05, 2011 9:18 am Pepsi_Drinker Mclaren .....Sorry off the subject but has anyone heard of doing something like this but smaller to install in a niche? We have two niches and I think slumped glass would look awesome if we were able to hang it in there. Any views?? Depending on the actual size of your niches (I gather you're talking about ones 1000mm-ish tall, not 400mm tall as in a shower niche) it could look pretty good. The only thing I'd caution is that sometimes (generally ??) slumped glass is a "bold" product, that is maybe why it works so well in large sheets. For your niches I'd probably be looking at a more "delicate" (less deep / pronounced) design for the glass ?? Or maybe tinted mirror ?? For fixing, say your niche "depth" was 90mm, I'd sit the glass / mirror flat into the niche, and then retain it with a 45mm * 45mm "beading" of some sort, painted seamlessly with the walls, so the glass would just appear to sit there with no fixing. In my mind anyhow !!! Cheers, P_D Thanks for your ideas P_D - the niches are 900mm wide and 1500 high so plenty of room - I agree the glass shouldn't be too heavy - I think it would look awesome though with the downlights above reflecting the shapes and colours in the glass. Cheers For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: LARGE glass panel for walk in shower 26Jul 05, 2011 10:44 am kerry-ann We are building with V too. As above is what i'm thinking of doing in our ensuite,sml part wall & then a glass panel because our shower is a double but with 1 shower head. Did they quote you a price for this Be interesting what it is through them,but i wont a glass panel not semi frameless. cheers I really want frameless too. Will PM you Re: LARGE glass panel for walk in shower 27Jul 05, 2011 11:08 am I have also found for the perth people a company that does panels fitted for $500,these if i remember right were 10m thick,now to find the website again Was something to do with frameless?? Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: LARGE glass panel for walk in shower 28Jul 05, 2011 12:15 pm framelessglasswa.com ? I found Alan @ allthingsglass.com.au to be really helpful Re: LARGE glass panel for walk in shower 29Jul 05, 2011 12:31 pm I have a single glass sheet shower screen. Mine is about 2500 high by 750 wide 10 mm toughened. Not sure how much it cost as it was part of the building contract. Supplier was Stegbar. No channel - glass is fitted to the wall and rests on clear plastic supports on the bottom, which when silcined in are not visible. At first I though of sealing to the ceiling, but there's a 5 mm gap and all is well. My screen is only 750 mm wide since the bathroom width is only 1500 mm! Obviously a better bathroom woudl be 2400 mm wide and then the screen coudl be 1500 mm or so. Looks great. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: LARGE glass panel for walk in shower 30Jul 05, 2011 12:41 pm alt0160 framelessglasswa.com ? I found Alan @ allthingsglass.com.au to be really helpful That could be it,haven't checked yet I am always shown as online,i work on the comp during the day & just keep a window open so i can check things. Cassa do you have a photo please Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: LARGE glass panel for walk in shower 31Jul 13, 2011 9:01 am just bumping this post again as I am getting quotes around the 2K mark, which is what I sort of expected. Does anyone have glass supplier in melbourne that they would recomend, I want to get this done right. Re: LARGE glass panel for walk in shower 32Jul 17, 2011 2:42 pm kerry-ann I have also found for the perth people a company that does panels fitted for $500,these if i remember right were 10m thick,now to find the website again Was something to do with frameless?? Bumping again, Also framelessglasswa are also selling etched glass panels due in in august & have great prices for mirrors fitted. check out their website Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: LARGE glass panel for walk in shower 33Jul 17, 2011 7:49 pm thanks cassa2 I had forgotten about stegbar, I have heard they arent the cheapest but dso a good job. Re: LARGE glass panel for walk in shower 34Jul 23, 2011 10:59 am pattycake4 I am having walk in showers I to saw panels at bunnnings 1200x2000 10mm toughened glass $234 That's fantastic! May I ask who you'd get to instal these - a plumber? Re: LARGE glass panel for walk in shower 35Jul 23, 2011 11:09 am the builder will get them installed via shower installer I am going to talk with installer direct as builder allows this,been small company it was standed fitting only in house price. If I want to upgrade then I deal with the tradie,keeps cost down. Re: LARGE glass panel for walk in shower 36Jul 23, 2011 8:41 pm Wow thats good Pced. Quickly passing through will check & see what your've been up to later Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3848 Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 8408 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6628 |
