Browse Forums Bathrooms and Laundry Re: bathrooms and laundries 3Jun 08, 2011 11:03 pm wayne6666 has anyone heard of puting coloured silastic into the corners of the shower walls etc instead of normal grout. I gather it's to allow for movement between the different pieces of backing board or wall that meet at corners (and floor for that matter). I was told grout should not be used in corners as it will crack and leak over time due to movement at that point. I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10033 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6177 Hi there, We've just build a new hardwood (Greybox) deck and am wondering whether firepit protective mats/surfaces are sufficient? I'm not sure that they're heat… 0 2116 |
