Browse Forums Bathrooms and Laundry 1 May 22, 2011 6:00 pm Hi We had a big leak onto our carpet from our ensuite all mouldy disgusting the plumber came said we could use someone to spray a membrane to fix the issue although it is only temporary. The grout was leaking into the wall and caused some strucural damage so we gutted the ensuite and started from scratch. When the carpet was being relaid we had to take the cupboards out of the walk in robe and lo and behold mould on the wall leading to the master bathroom not as bad as the ensuite no carpet issues just a patch on the wall. Plumber thinks it should be ok to just ge someone in to regrout and seal the shower as there is no way we can afford to do this as well. I have 2 people coming out to quote but was wondering does any one have any reccomendations in Melbourne? The joys of older homes DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11584 |
