Browse Forums Bathrooms and Laundry 1 May 02, 2011 10:19 pm Does your frameless tiled shower need a metal rim along the floor on the door opening edge? Is this a building standard? I hven't noticed this when I've seen them in display homes but my builder is telling me it needs that. Thanks for yoir input Re: Rim on floor required in shower? 2May 03, 2011 7:51 am Yep, it's a bit of angle aluminium. The waterproofing runs up to this edge. A good tiler will ensure the finished floor level is flush with the top of the aluminium, and you'll never see it. Should also be a piece at each door way. Paul Re: Rim on floor required in shower? 3May 03, 2011 8:16 am leanne27 Does your frameless tiled shower need a metal rim along the floor on the door opening edge? Is this a building standard? I hven't noticed this when I've seen them in display homes but my builder is telling me it needs that. Thanks for yoir input Yes it absolutely does, otherwise you can end up with water travelling under the tiles (tiles/grout are porous) and ending up anywhere... it's called 'waterstop'. Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4682 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5447 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2126 |
