Browse Forums Bathrooms and Laundry Re: floor level changes into bathrooms / showers etc etc 2May 01, 2011 9:47 pm Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: floor level changes into bathrooms / showers etc etc 5May 03, 2011 4:48 pm It all depends on what the tiler is comfortable with. They need to get the fall. If the waste is near the door in a small bathroom, maybe 20-25mm (dont forget tiles and glue are 8-10mm). Big room, waste 4m away,could be 40mm. Also depends on the height of your floor coverings. Tell/show the tiler the floor coverings, tell him you want it pretty flush, and he can work it out. It will always be a bit proud. ".....teach people the flanges are rubber and are damaged when a gorilla turns them off....." isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 10343 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46956 |
