Browse Forums Bathrooms and Laundry 1 Apr 12, 2011 8:33 pm Hi everyone, Does anyone know the difference in cost between a Frameless and Semi Frameless Shower Screen? We have a shower which is 1.8metres long (wall to wall) and our builder has suggested having a 10mm thick frameless shower with a pivot door at the far end. We actually prefer the look of a semi-frameless for this space. The builder hasn't told us the costs yet for either and I was hoping someone could give me a guide to what we should expect to pay? We need to decide tomorrow so any advice tonight would be really appreciated! Thanks Re: Frameless vs Semi-Frameless Shower - Costs? 2Apr 12, 2011 8:39 pm At least 50% more. I got quoted from my builder using Stegbar. Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: Frameless vs Semi-Frameless Shower - Costs? 3Apr 12, 2011 8:59 pm Have you thought of a walk in shower 10mm glass panel Re: Frameless vs Semi-Frameless Shower - Costs? 4Apr 14, 2011 2:31 am Hi 75etd, there 4 types of screens that could be used in your bathroom, *framed *semi-framed *perimeter *fully frameless These could range from $500 to $2000. Be aware that that is quite a wide shower and depending on your budget I would either recommend fully framed or frameless. These are the most sturdy, having said that, the other deigns will work fine as long as you are aware that they will have some flex. Re: Frameless vs Semi-Frameless Shower - Costs? 5Apr 22, 2011 12:48 am Yes, frameless showers tend to use thicker glass...½ inch glass panels and ⅜ inch doors for maximum stability. Also, they are as the name implies have to frame, just glass panels. No header is needed in most cases. Semi-frameless showers have a framed perimeter around the enclosure, while the door is frameless...no channel at the top, bottom or on the handle side. Both are stabilized by a header and are installed with wall jams and a bottom sill. Here's a perfect example of semi-frameless showers and shows a diagram with a channel, header, and wall jam. Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37715 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25166 2 4496 |
