Browse Forums Bathrooms and Laundry 1 Mar 19, 2011 2:25 pm Hi, We're in the process of potentially switching our plans from a lift and build under renovation to removal and rebuild. In our renovation plans, we had our new downstairs bathroom directly below the existing upstairs one, thinking this would be efficient, save money, etc. These days, is this line of thought valid? If we do build new, will it matter much if the upstairs and downstairs bathrooms are in different parts of the floorplan? Cheers, Mick. Re: Having upstairs and downstairs directly above each other 2Mar 19, 2011 2:55 pm FWIW it is more cost effective to position wet areas on 1 side, above is as good as it gets. all on 1 of the sides is a heap easier for plumbing, but can only imagine as it is NOT my trade. I figure drainage would be more important that hot & cold feed lines and could become an issue. But then if you want something a special way for some reason, then $$$ are not a consideration. IMHO only Where you are coming from is where you are going to... Not unless you have managed to put it as a special condition into the contract somehow. 1 6157 I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6311 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10049 |
