Browse Forums Bathrooms and Laundry 1 Mar 08, 2011 10:40 pm My house has an old Junkers instant hot water service.. Here is a link to a photo: http://s891.photobucket.com/albums/ac11 ... unkers.jpg It works a bit too well - it can do "regular" temperature hot water but if the tap is more than about 1/3 on, the water becomes scalding hot.. Anyone familiar with this brand, please have a look at the picture - and I'd be grateful if you could tell me which settings I should use for the buttons/knobs to lower the temperature... or is this more of an issue of a busted thermostat? Appreciate any ideas.. Re: Junkers Hot Water - too hot! 2Mar 09, 2011 8:20 am Perhaps you could look at a tempering valve like they put in new houses? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14059 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
