Just a question about tap placement for the bath - I need to decide asap so I can let the builder/plumber know and I kinda forgot about it.
The bath with be an island setting (so set up about the tiles out from all the walls).
I was thinking of putting the taps at the end of the bath, with the spout on the side in the middle of the bath. Do you think this would work?
My other idea was to have the taps and spout all on the far side of the bath on the long side in the middle, but then it might be a bit of a reach to get to the taps, as you would have to reach over the bath which is 700mm wide plus tiling around either side so it could be 900mm wide.
Where are your taps and do you like them in that position, if anyone has pics that would be handy too
