Browse Forums Bathrooms and Laundry 1 Feb 18, 2011 12:39 pm We took out the mirror in the ensuite on the house plans as we were going to put in a shaving cabinet instead. There is a square space of wall where it would have gone. Is it best to: - tile that space (we still have a box of tiles left from the builder which is enough) and then fix the shaving cabinet on or; - fix the cabinet on, and tile around it? There will be little bits of wall either side if we dont tile, but there'd be a lot of cutting of tiles. Thanks Re: Shaving Cabinets - install over tiles or on wall? 2Mar 02, 2011 7:30 am can't you use full tiles and then put the cabinet over the top? We're putting full tiles around the edge of the cabinet and leaving the big space behind the cabinet as bare wall. Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15324 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 424 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10089 |
