Browse Forums Bathrooms and Laundry 1 Feb 15, 2011 6:13 am I have two old toilets, which have an 'S' trap has a vent pipe (50mm) running directly from the S bend, out the exterior wall and up to a vent pipe to the roof. Also there is a 100mm vent stack pipe about 10 meters away from the location of the toilets. Is this vent pipe still required if install new toilets? Any information would be appreciated. Thanks. Re: Toilets with vent pipe 2Feb 15, 2011 7:51 am Is that one specifically required NO Do you need A vent (stink pipe) YES This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 10552 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5996 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7339 |
