Browse Forums Bathrooms and Laundry Re: Ensuite Drain Blocking 5Jan 29, 2011 8:59 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Ensuite Drain Blocking 7Jan 29, 2011 9:30 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Ensuite Drain Blocking 10Feb 09, 2011 6:31 am Go and see a plumbing store about a gratemate or grateseal (or drainseal, something like that). Its an item that you insert into the waste pipe that stops the smells and foam coming back up. Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But… 0 503 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 873 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4576 |
