Browse Forums Bathrooms and Laundry Re: Ensuite Drain Blocking 5Jan 29, 2011 8:59 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Ensuite Drain Blocking 7Jan 29, 2011 9:30 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Ensuite Drain Blocking 9Feb 05, 2011 8:21 pm I have found the best way to clean centre drains and shower drains is to use a round toilet brush , buy a cheap round brush from ikea, remove the grate ,make sure the drain is wet and brush away, then rinse with hose or bucket, works a treat provided the drain is not to deep. May need some shower cleaner or mould spray to break up the filth. There is an s bend at the bottom of the drain which will then branch off to the 100mm toilet pipe, so shouldnt have any sewage in drain. Re: Ensuite Drain Blocking 10Feb 09, 2011 6:31 am Go and see a plumbing store about a gratemate or grateseal (or drainseal, something like that). Its an item that you insert into the waste pipe that stops the smells and foam coming back up. Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But… 0 505 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 892 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4615 |
