Browse Forums Bathrooms and Laundry 1 Jan 08, 2011 10:46 pm Heya Just wondering about anyones experiences with mini corrugated iron cladding in a bathroom. Is it ok for wet areas? I have an,,, shall we say vintage bathroom with asbestos and wall paper. Yeah sounds like work. Can i take the easy option and (not rip down wall paper and not deal with asbestos too much) just clad it all with some mini corrugated iron. I think it would look allright,,, I think, even though it will go to ceiling (9ft). Thoughts feelings and advice greatly appreciated!!! Re: Mini corrugated iron cladding in a bathroom 2Jan 09, 2011 5:34 am I'm sure it will be fine in a wet area! A friend has some corrugated iron on her loo walls. I have a feeling it is only to dado rail height. I can remember thinking that it felt like I was sitting in an old outdoor loo (minus the spiders!). I'm pretty sure that was the effect she wanted and it fits with her house well. Even though her house is quite modern, it has a lovely 'in touch with nature' feel. Perhaps floor to ceiling would be too much - hard to tell without seeing your loo first? If you ran it vertically it would emphasis the roof height and perhaps make the room feel narrower and like a shaft. I suspect horizontally may look better. You could always sheet directly over the top of the asbestos sheets with VJ panelling or just plain villaboard. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 We have a Victorian style ripple iron fence out the front that has some moulded timber capping. Probably 15+ years old and has cracked and splintered in parts...not really… 0 2491 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12046 |
