Browse Forums Bathrooms and Laundry 1 Jan 01, 2011 6:55 pm For those with large mirrors in bathrooms, does it go all the way to the ceiling? Do you have a wall light above it? Or do you have a bulkhead on that wall? Also, is the mirror also a splashback or is it tiles or glass? Re: Do you have a large mirror in your bathroom? 2Jan 01, 2011 7:02 pm We have always had large mirrors in the bathroom. They are used as splash backs and are generally stop about 1.8m from the floor. Most of the actual splashes are about 4-500mm from the top of the vanity 9generally tootpaste splashes. We don't bother with any special lighting we just use the central fitting as the mirror is so big you can just step a bit to one side or the other to get good light on that side of your face. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Do you have a large mirror in your bathroom? 4Jan 02, 2011 7:58 am Ensuite has mirror 120mm across by 75 up, other bathroom 150 across by 75 up - both go full width of vanity bench but start 2 tiles up from the bench - yes, they have over mirror light on the wall additional to the bathroom ceiling light. Re: Do you have a large mirror in your bathroom? 6Jan 02, 2011 10:29 pm Thanks for your responses Do you have cornice directly above the mirror? Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39450 DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 1614 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6610 |
