Browse Forums Bathrooms and Laundry 1 Jan 01, 2011 3:55 pm We are building our first house in Sydney, and it's now in the bricklaying stage. The windows have been mounted on the frames, and we found the design of the window in the bathroom is quite awkward. The final result will be like this. This image is not mine, I found it on the forum, but it's just the same as mine. http://i234.photobucket.com/albums/ee29/clath_photos/Image095.jpg The bathroom is on up floor, I think there may be a safety concern. My question is, is there a regulation or law about the window height in bathroom? Can I ask my builder to change this for free? For example, change the window to lower half fixed and upper half sliding. Considered the window has been installed, if they are going to change it, it may cost a lot. If the builder is not going to change it, I think may be I can put a security screen on the window. Is it common of this kind of security screen? How much will it cost? Thanks Re: window over bath 2Jan 01, 2011 5:01 pm A glazier told me that there are regulations about using thicker glass within a certain distance of baths - I assume so that if someone slips and falls against the window, they're not going to go straight through it. There may (should?) be regulations regarding the height of openable windows on upper storeys, which is an entirely separate thing, but I don't know. I can find a lot of references to overlooking, but none about safety. Ed might know.... Re: window over bath 3Jan 01, 2011 5:43 pm I know our opening windows on the upper level had to be above 900mm or have security grills, bars etc to meet certification. Thats in qld. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: window over bath 5Jan 01, 2011 10:36 pm There is no minimum sill height. The sill can be at floor level. But there is a limit to the amount the window can open when the sill is below 900mm. That limit is 150mm. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: window over bath 6Jan 04, 2011 7:43 pm ed @ EcoClassic There is no minimum sill height. The sill can be at floor level. But there is a limit to the amount the window can open when the sill is below 900mm. That limit is 150mm. Ed Thanks Ed. Is this Australian standard? Does it apply to NSW? Re: window over bath 7Jan 04, 2011 10:03 pm tony2000 ed @ EcoClassic There is no minimum sill height. The sill can be at floor level. But there is a limit to the amount the window can open when the sill is below 900mm. That limit is 150mm. Ed Thanks Ed. Is this Australian standard? Does it apply to NSW? Yes Australian Standards.. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed. 1 1807 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5229 Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 24690 |
