Browse Forums Bathrooms and Laundry 1 Nov 25, 2010 3:12 pm Does anyone have a double sized shower where the water just tends to sit at the far end and not drain away properly? I LOVE having a big shower, but find the grout at the far end gets dirty from water just sitting there on it at all times! I'll go into the shower hours after having the water on, and those tiles will still be wet. There is no slope down towards the plug hole and obviously no slope up that end to cause the water to run down. Should it have this?? How the hell did I become a senior member!? I know nothing! Re: Double sized shower - problem with water pooling 3Nov 26, 2010 8:11 am Depends on when your unit was built Grace and what the standards where at the time. Every state seems to have differing rules plus over time they change the standards. Some things are worth waiting for. Re: Double sized shower - problem with water pooling 4Nov 26, 2010 4:07 pm Hmm...maybe there is a TINY slope, but I can't detect it and the water surely doesn't react like there is! The building is 14 years old. How the hell did I become a senior member!? I know nothing! This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28290 Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 6940 If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12094 |
