Browse Forums Bathrooms and Laundry Re: Removing bathtub 2Nov 25, 2010 7:32 am dont have pictures but it is a standard bath setup with brick surround support under lip and tiled - typical new home setup Its plastic/fiberglass. I saw online in US that u can unscrew the drain from inside the bath is this still applicable for ozzy baths but?. Re: Removing bathtub 3Nov 25, 2010 12:25 pm dingdong don't have pictures but it is a standard bath setup with brick surround support under lip and tiled - typical new home setup Its plastic/fibreglass. I saw online in US that u can unscrew the drain from inside the bath is this still applicable for ozzy baths but?. I don't think so you can pull it out without breaking few tiles as silicone would have a good grip besides there is little to do with US plumbing standards and our own. You can try if it break then fix it. Re: Removing bathtub 5Nov 27, 2010 11:44 am Hi. We've recently, like a fortnight ago, pulled out our old Bathtub of the style you are discussing and replaced it with a new, deeper, model. Before beginning we went to Bunnings, had a look at the Baths, Outlets and P-Traps (The Plumbing fitting between the Outlet and the "inground" Pipes) and worked out how it all fitted together before we began. I'm pretty sure unscrewing it from the inside wouldn't have been possible but I'd advise going down as we did and having a look at how it goes together before you begin. Thanks. Re: Removing bathtub 6Nov 28, 2010 6:50 pm You will need to punch a hole in the side of the brickwork nearest the waste and unscrew the fitting from the bath . No way can you do this without getting inside. If you are replacing the bath you will more than likely find that the new bath will not suit the existing brickwork and will have to be redone. Re: Removing bathtub 9Nov 29, 2010 2:19 pm just like a sink then? thats insane why are we behind the world always when it comes to this stuff? What whith the special tool u can buy then that unscrews it from the inside and why did i see an ozzy clip and read about it online? Re: Removing bathtub 10Dec 02, 2010 7:57 am dingdong just like a sink then? thats insane why are we behind the world always when it comes to this stuff? What whith the special tool u can buy then that unscrews it from the inside and why did i see an ozzy clip and read about it online? Please give us a link to this clip. I want to see magic in action... Have the same problem with bathtube and don't want to get under the house. Apparently you can break tube with hammer. You need good eye protection and full sleeve clothes, it breakes to small sharp pieces. Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10378 6 11152 The best advice is for you to get a competent building consultant to guide you through your build 7 4687 |
