Browse Forums Bathrooms and Laundry Re: Sealing and protecting Marble tiles 2Nov 18, 2010 8:05 am SOunds lovely! The grouting is usually done before the sealing, but I believe that with porous stone the tiles are often sealed once before laying & then again at the end. This is to stop the water from the grout seeping in the edges & creating 'picture framing'on the tiles. Hopefully this won't happen. Apparently lithofin is excellent. So is aquamix. You definitely want a penetrating type sealer. Be aware that with these products you only get the guarantee if you use an accredited installer. Hi All, This is my first bathroom Reno and tiler has just finished installing marble tiles…only problem is they don’t look right? There are holes in the grout, really… 0 4590 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6711 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 1982 |
