Browse Forums Bathrooms and Laundry Re: Replumbing Ensuite-swapping toilet and shower 2Nov 07, 2010 9:36 pm Alza21 Hi, am scouting out ideas for renovating our (small) ensuite. Would like to swap toilet and shower to make room for bigger shower. Is this a crazy idea, does anyone have any ideas about how much it would cost? It could cost you a small fortune if re-plumbing is on the cards no much for the new pan, flush tank and shower cubicle but there is a cost for the shower base, may be drain hole and relocation of the waste pipe. Where do you live anyway? I may be able to help you Re: Replumbing Ensuite-swapping toilet and shower 3Nov 08, 2010 11:16 am We live in Perth, house is mid-80s, concrete pad. Would definitely need to relocate waste pipe. Might be able to use toilet pipe for shower drain? Am prepared for cost of new shower etc, but have no idea about cost of moving pipes around/through pad? Re: Replumbing Ensuite-swapping toilet and shower 4Nov 09, 2010 7:35 am <textarea name="message" rows="15" cols="76" tabindex="3" onselect="storeCaret(this);" onclick="storeCaret(this);" onkeyup="storeCaret(this);" onfocus="initInsertions();" style="width: 98%;"> Definitely it would cost you although Perth may be less of a cost than Melbourne or Sydney I would say $3000 to 5000 all depends of the pipes, tiles, walls etc. You may need a project person or a builder to coordinate work if involves two or more trades. I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10088 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6169 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11858 |
