Browse Forums Bathrooms and Laundry Re: Stupid question 2Oct 21, 2010 7:40 pm apollo13 Is it possible to connect galvinised pipe to pvc pipe? What type of connecter would i need for this job? thanks Yes it is, thread sizes are the same so no drams with this problem. If you've cut off a gal pipe, you'll have to thread the end using a die, use a female-female gal joiner, then a screw-plain adaptor to join the plastic onto the pipe. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9961 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6153 1 13126 |
