Browse Forums Bathrooms and Laundry Re: Polished Timber Floor in an Ensuite - can it be done???? 6Oct 21, 2010 10:42 am I think any splashes of water that will leave specks/marks on the floor will eventually drive you nuts Practicality would prevent me from having floorboards in a bathroom but good luck if you can be bothered with them Jazz Life is like a lolly, suck it and see Re: Polished Timber Floor in an Ensuite - can it be done???? 7Oct 22, 2010 3:22 pm There are timber look tiles on the market. We have been importing them for 13yrs and regularly use them in bathrooms. If you click my link you will see them on my site. The most important thing is as there are planks i.e 15x90cm long each you will need to run a slot drain across the room. Cheers Charlie Re: Polished Timber Floor in an Ensuite - can it be done???? 8Oct 22, 2010 4:18 pm Thanks guys... might think about a stone floor then... if it is most likely it is going to rot the floor boards then might go the more conventional route. thanks Belinda Reno in Southport - QLD. So much work to do and timeline has already been pushed back!!! Still To Do - security system, security screens, tree removal (cocus palms), internal works, lighting, ensuite. I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15265 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11630 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6138 |
