Browse Forums Bathrooms and Laundry 1 Oct 15, 2010 7:11 am Hi, I need your wisdom guys… I have a bit unusual and cramped layout with corner spa bath. In my original plan, I was going to install wall hung, semi-recessed vanity unit on the full available width 1500 mm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ However plumber recommends me to use 900mm vanity unit and leave some room for towels. In his opinion, 1500mm unit will look too big. Here is what he recommends Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I’m torn apart… I want more room for cosmetics etc, don’t really like everything on display. Re: Vanity unit: wide or standard? 2Oct 15, 2010 1:14 pm Personally I'd prefer more benchtop. It's not that far to turn and reach the main towel rack and you could mount a handtowel ring on the wall above the vanity next to the wall. Advantages I can see: * a larger mirror over a long vanity would make the room look bigger * a longer bench means you're less likely to knock cosmetics into the sink * a longer bench gives space for someone to be using the mirror for makeup etc while someone else washes hands Possible disadvantages: * Are you 100% sure about your internal wall measurements and that the 1000mm shower and the 1500mm vanity will fit next to each other? * perhaps not being able to clean the shower wall next to the vanity HTH Kylie Re: Vanity unit: wide or standard? 3Oct 15, 2010 1:24 pm I would go for the 1500 as well. If you have a hairdryer, brushes, hair straightener, cosmetics, tissues, soap pump etc etc...you will need that space as yes gentlemen, we do have them all out at one time and agree with kb46 comments. Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25163 Any joinery expert, please advise. Is it possible to add drawers in this 750mm wide joinery in a small bathroom. My builder told its not possible… 0 416 |
