Browse Forums Bathrooms and Laundry 1 Oct 11, 2010 10:41 pm We are renovating our bathroom and have an old ivory coloured bath that we'd like to make white. I've had a couple of quotes for re-surfacing/spraying and they are around the $600 mark, which seems pretty expensive. There are DIY kits out on the market. Has anyone used one and know if they're ok? http://www.tubbydiy.com.au/8-resurface.html http://www.whiteknightpaints.com.au/pro ... tub-n-tile Our bath is in pretty good condition, so we really only need to make it white rather than repair damage. Any thoughts? Re: Has anyone used a DIY kit to resurface a bath? 2Oct 16, 2010 8:10 am When i revonated my rental property i had the same problem a friend of mine told me that he painted he's bath and shower base in 2pac white. If you know someone handy with a spray gun like a panel beater/spray painter prep the area with high fill rub back spray with 2k white wait to dry, rub with 1200 paper and cut and polish looks amazing. Cost me under $100 dollars for material and it's been 3 years no problem.... http://allyslilcastle.blogspot.com/ Re: Has anyone used a DIY kit to resurface a bath? 3Oct 16, 2010 9:21 am Hi cookie I have not done it yet however i have the same predicament my bathtub is also kind of light ivory/brown and it has peeled off showing a blue layer so if painted it would be uneven. What Ally recommend it may not be practical since you need a special airless gun (expensive) to use with 2pak besides 2pak is highly quite toxic I would be inclined to sand back the bathtub and then use the resurfacing kit at least you have all the ingredients to use in that kit anyway. White king I would use it more for tiles rather than bathtubs. Check out your local paint shop too they should be helpful with priming, undercoats and enameling paints. As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17847 Hi All, we are starting to think of building with Masterpiece Builders in Victoria, has anyone had any feedback or experience with them 0 13567 Hi we are looking to talk to people who have built with them recently. We have signed mid range built contract but identified that a lot of things are not included.… 0 643 |
