Browse Forums Bathrooms and Laundry 1 Oct 11, 2010 7:02 pm I'm redoing a bathroom and would love slate tiles or something that looks like it. I found a company called Refin that produces porcelain tiles that's 4.8 mm thick that can be laid over exisiting floor tiles. I'm going to call a distributor in Victoria tomorrow, but was just wondering if there are other brands that can do this too and if it's strong enough to withstand normal wear and tear and resist cracks, especially with larger-sized tiles? It would be a time and labour saver but I know I'm going to pay more for the tiles. Re: Porcelain Floor Tile That Can Lay Over Existing Tile 2Oct 16, 2010 9:35 am Quite interesting wally I need thin tiles too to keep floors even. So is there a rep in Victoria? I want to know more about thanks It is called Skin I have the problem of leveling out with timber floors so I need thin tiles that will not get the fllors out of level. Re: Porcelain Floor Tile That Can Lay Over Existing Tile 3Nov 05, 2010 1:19 pm 3mm Porcelain ceramic Check the website www.laminam.com distributed in Australia via Plastral www.plastral.com.au Cheers Re: Porcelain Floor Tile That Can Lay Over Existing Tile 4Nov 06, 2010 12:14 pm My supplier in Spain dabbled into the 4mm tiles - The Film series. They have stop making them for floors and concentrated on wall up to 90cm long. The feedback I got from them was that there where issues with the way the tile had to be laid on floors - and then getting tilers to follow the specific steps required. I assume it had more to do with getting falls to wastes etc...and reduceing lipping. But if overall floor height is not an issue you can use any thickness tile...as long as the right adhesives are used and the original floor is sound. Cheers To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 373 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8408 I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 12895 |
