Browse Forums Bathrooms and Laundry Re: Drain Clean 2Sep 17, 2010 12:19 pm NcgQ Hi I got a blocked shower and Bunnings recommended "Drain Clean - Hair Unclogger" - anyone knows these products are safer to use? If now, what is the best way to clean drain? Thanks No idea, but even if it's hair I think a rubber plunger would do the trick. Place over drain, fill shower tray and pump away. It works 99% of the time for me. Buy one in Bunnings... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4539 Agreed. I just found out today the certifier has not given the final sign off. 2 4091 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8467 |
