Browse Forums Bathrooms and Laundry 1 Sep 11, 2010 8:34 am Hi there, I recently did the final inspection of my new place and found some sort of a water mark on the marble wall right next to the bathtub. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Would appreciate any feedback as to what you think that water mark is ... e.g. is it just stain? or is there a leak behind the walls? All feedbacks are welcomed. Thanks! Signed: June 2010 | Settlement: September 2010 | Moved in: October 2010 Re: Water mark on marble wall in bathroom? - Advice needed! 2Sep 11, 2010 9:33 am bunnywabbit Hi there, I recently did the final inspection of my new place and found some sort of a water mark on the marble wall right next to the bathtub. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Would appreciate any feedback as to what you think that water mark is ... e.g. is it just stain? or is there a leak behind the walls? All feedbacks are welcomed. Thanks! A wider view would be good... but unlikely to be a leak at that height and so localised. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Water mark on marble wall in bathroom? 3Sep 11, 2010 9:43 am I've seen this a few times. I suspect water is trapped in the frame, rising up to the screw fixing the frame and then making an exit. Cut away some of the caulk from inside (just the inside) of the shower at the bottom corner and see if water dribbles out. Re: Water mark on marble wall in bathroom? - Advice needed! 4Sep 13, 2010 12:16 pm ed: Thanks, I will try to get another picture this week. TheOK: Thanks! Will take your suggestion into point. Signed: June 2010 | Settlement: September 2010 | Moved in: October 2010 Re: Water mark on marble wall in bathroom? - Advice needed! 5Sep 18, 2010 7:35 pm ed @ EcoClassic A wider view would be good... but unlikely to be a leak at that height and so localised. Ed Hey ed, Here's a wider view : Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The shower head just got cropped off the frame. It's just above the mirror tile in the tub (if that makes sense). Signed: June 2010 | Settlement: September 2010 | Moved in: October 2010 Re: Water mark on marble wall in bathroom? - Advice needed! 6Sep 19, 2010 9:16 am A couple of questions... 1) Did the stain develop slowly? 2) Is the stain on both sides of the shower frame? 3) Can you see a screw near the stain? Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Water mark on marble wall in bathroom? - Advice needed! 7Sep 19, 2010 9:27 am 1) Not sure. I just noticed the stain during the final inspection. Not too sure if the stain were there when I bought the place though. 2) The stain is only on the outer side of the shower frame. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3) Nope, no screws. The stain seem to have lighten when the previous tenant hired a pro cleaner to clean the place when they were vacating the apartment. Do you think I should get a plumber in to inspect? Thanks, Ed. Cheers, Lynn Signed: June 2010 | Settlement: September 2010 | Moved in: October 2010 Re: Water mark on marble wall in bathroom? - Advice needed! 8Sep 19, 2010 11:47 am It's a stain so unless it's growing (or damp), I don't think you need a plumber, it's very hard to treat if you don't know the cause. Is it rust? There may be a screw behind the shower frame or a nail behind the tile which is either rusty or corroding because it is not stainless. If you think rust is possible, I would buy some rust remover, test it in a small area away from view and if it does no damage, try it on a small part of the stain. Ed Any other ideas anyone...??? "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Always get multiple quotes, no matter how reasonable/cheap you think it is. I remember getting a few quotes for a pool fence, roughly around the same price, thinking the… 5 9690 Hi All, This is my first bathroom Reno and tiler has just finished installing marble tiles…only problem is they don’t look right? There are holes in the grout, really… 0 4599 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
