Browse Forums Bathrooms and Laundry There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 7981 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6062 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8370 |
