Browse Forums Bathrooms and Laundry 1 Jun 19, 2010 1:55 am Hi all, Just wondering on my options if i do not want to go hobless? How wide and how high does the hob in a shower go? What's the minimum height and width without affecting its design purpose? I've also seen where a thin metal, most probably only 2-3cm high is used. Just wondering if other people have built this and it it has served it's purposes? Re: minimum shower hob size without going hobless? Options? 2Jun 27, 2010 11:42 pm Found a company that eliminates the usual hob for the shower. It's effectively a metal strip along the foor acting as the hob, thus now you can effectively have different floor heights ie. inside the shower would need a higher height to allow draining. Then the standard floor can be lower so it keeps more in line with the rest of the house. http://www.waterstopstreamline.com.au/ Re: minimum shower hob size without going hobless? Options? 3Jun 28, 2010 2:11 pm I'm having no hob in my shower. Basically, waterproofing extends to the edges of the bathroom, not just the edges of the shower. This way, the floor ha a clean-line continous look. Demolition August 2009, Construction Started September 2009, Completed December 2010 Hello I'm remodeling my kitchen and evaluating ideas. We are in the last stages of drawing and I am now considering putting a pot filler tap in above the hob. Has anyone… 0 1367 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6868 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5369 |
