Browse Forums Bathrooms and Laundry Re: List of tradies needed 3May 25, 2010 12:12 pm demolition, your mate can do most of it himeself except water & electrical. to rebuild he will need: - electrician - carpenter (if you want to modify walls) - plumber - plasterer (most likely will need as the tiles will tear the plaster when coming off the walls) - tiler if your mate can get a vanity unit already made up, he can most likely mount it himself if he has half decent skills and the right tools... when installed, you'll need a plumber to come and terminate the water & waste. theres a bit involved, so make sure your mate has a good plan... e.g - if he wants to move stuff around, he'll need the plumber and electrician in at "frame stage"... that said, if everything is getting replaced in the standard locations it will make things a lot easier for him. Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 20901 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6900 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7004 |
