Browse Forums Bathrooms and Laundry 1 May 12, 2010 2:01 pm Our builder includes a Dux Endurance 20p instantaneous gas hot water system as standard. We are happy enough to have a Gas hot water system as we are also having a gas cooktop, but was just wondering what people thought of the instantaneous system vs storage system or if you really would recommend going electric instead? We are a family of 4 so do use a bit of hot water. Any advice is much appreciated Thanks! Emma Emma Building on an acre at Teviot Downs, Brisbane Building through Hallmark - Flair 253 with a few changes Mother of two gorgeous girls Build thread: viewtopic.php?f=31&t=37178 Re: Please help with hot water system selection 2May 15, 2010 9:12 am Our previous houses have had storage heaters (both electric and gas) but our new house will have an instantaneous gas heater. We're going this way because it's smaller, easier to locate, never runs out of hot water, etc. With our previous gas storage unit we found the recovery rate was too slow if you had people using the shower one after the other. Friends and family who have gas instantaneous heaters say they would never go back to storage unless it was part of a solar system. With a family of four I would personally put in a 24 or larger unit, especially if you have multiple people using hot-water at the same time. How many bathrooms, etc. does your new house have? Re: Please help with hot water system selection 3May 15, 2010 9:15 am Maybe up it to the 26 if you are 4 people and are thinking of having a couple showers at once. I know rinnai do a 26. Re: Please help with hot water system selection 4May 15, 2010 9:35 am Why would anyone choose an electric HWS if they can have gas? Go the gas ...and instantaneous is excellent. Solar plus gas booster is even better, but will push the cost way up. Apart from never running out of hot water, it's way cheaper to run than any storage system, since you're only heating the water you use. Last time I checked the stats, these systems are only beaten on running costs by solar. Re: Please help with hot water system selection 5May 15, 2010 9:26 pm Thanks so much. I should have specified too, we will be using bottled gas, we don't have gas pipelines where we are building. Will that make a significant $ difference? Emma Building on an acre at Teviot Downs, Brisbane Building through Hallmark - Flair 253 with a few changes Mother of two gorgeous girls Build thread: viewtopic.php?f=31&t=37178 Re: Please help with hot water system selection 6May 16, 2010 9:29 am emlet01 Thanks so much. I should have specified too, we will be using bottled gas, we don't have gas pipelines where we are building. Will that make a significant $ difference? H'mmm, that changes things a bit, bottled gas can be a lot more expensive. You may want to look at getting a solar system with an integrated instantaneous gas backup if your area and positioning are suitable. An electric heat pump hot water system would also be a good choice in this case. www.dux.com.au/products.php?name=D2FH00000C There are lots of other hot water heat pump units available, the link above is just for reference. Re: Please help with hot water system selection 7Aug 13, 2010 11:28 am Thanks everyone, we have gone for a solar system with an electric booster. Emma Building on an acre at Teviot Downs, Brisbane Building through Hallmark - Flair 253 with a few changes Mother of two gorgeous girls Build thread: viewtopic.php?f=31&t=37178 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14078 The tank is around 200 litres (I am on holiday for the next 6 weeks so can't check) The Heat Pump has a built in time switch. No idea on the speed to heat because with… 6 1734 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 |
