Browse Forums Bathrooms and Laundry 1 May 02, 2010 11:00 am Hello All, Has anyone used frosted glass as an alternative to a wall in a Bathroom? I ask as I'm looking to use it to separate (i) the shower area from the rest of the Bathroom, and also (ii) to separate the WC from the rest of the room. Has anyone got any thoughts on this? I'm building in Melbourne so if anyone can recommend a particular company who can potentially supply it then that would also be useful. Thanks in advance, Chorlton TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: Frosted Glass as a partition in the Bathroom 2May 02, 2010 3:36 pm Won 't be a problem. I have a full height glass panel for the shower area. By the sounds of it, you would want two of these, but in frosted glass, not clear. Here is a "during construction" pic of our ensuite. Stegbar did the shower screens. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Blog is now up - http://www.jbdave.blogspot.com/ Re: Frosted Glass as a partition in the Bathroom 3May 03, 2010 11:40 am Hi jbdave, Thanks for the reply. Out of interest, what distance do you have from your inside wall to the centre of your basin? I ask as I currently have 400mm (inside wall to basin centre), and I'm not sure whether that’s enough. My basin width is 440mm which means I would only have 180mm from edge of basin to inside of wall. Just trying to get a feel as to what others have….. Thanks in advance…. TIMING OF BUILD 25Feb - Site Start 25Mar - Base Stage Complete 31Mar - Frame Completed 11Apr - Roof Tiles 20Apr - Brickwork Started Re: Frosted Glass as a partition in the Bathroom 4May 08, 2010 9:23 pm Here is one where they have used it to close in the toilet in the ensuite, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1935 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39227 |
