Browse Forums Bathrooms and Laundry Re: hydronic heating systems for bathroom floors 2Apr 30, 2010 10:53 am Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: hydronic heating systems for bathroom floors 4Apr 30, 2010 6:18 pm vvs mand youre prposing something that will only half work at the best of times. ive installed lots of central heating systems in northern europe and when lines are laid in the floor they are controlled by a thermostat and are on a dedicated central heating system that has flow and return lines that circulate from a heat exchanger or boiler. what youre proposing wont heat the floor up until you run water through the shower and unless your showers are long, will hardly be noticable, unless you put a circulation pump on the branch to the bathroom, in which case the efficiency of your hot water system will be compromised. Thanks mate, this is what I wondering. Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4890 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4822 2 4688 |
