Browse Forums Bathrooms and Laundry 1 Mar 25, 2010 12:12 pm When removing the existing villaboard from the bathroom walls I found that the tiles go below the level of the concret floor, i.e it looks like the concrete floor was added after wall tiling had been done. When I put the villaboard back on, there will be gap between the floor and the wall which is the width of the old tiles. The question is, what should I fill the gap with and how do I waterproof the join between floor and wall? Re: Sealing between cement floor and wall 2Mar 25, 2010 12:14 pm what i did in my house is firstly buy special silicon, its a grey color but designed for this situation. (it fairly industrial strength) bunning have it in there plastering section. Then I use davey K10 or was it K26, and painted on one coat. Then stuck fiber glass in the corners then painted another two coats on.
Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4480 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3157 |
